MT-4 features:
channel control (built-in antenna)
Large LCD screen (128x64 dot)
New receiver (RX-461)
Built-in telemetry function (receiver voltage, speed, temperature)
Dual D/R ratio adjustment
SUB TRIM
TIMER (Lap / INT / Down type)
ABS
The volume adjustment (steering, throttle adjust volume)
AUX1, AUX2 mixed control
CH SET 1-4 ch all settings (D/R, EPA, SPEED, EXP...etc.)
Fail Safe funtion
8 digit username and model name input
20 group model memory
Modulation (DS2, FH3, FH, 3F, FH4T)
Throttle mode (5:5 , 3: 7)
TX Power source (4 x AA batteries)
Compatible receivers (RX-371, RX-442DS, RX-451, RX-451R)
Trigger position adjustable (front/rear slide 5mm , left/right 3° )
Hört sich soweit ja garnicht mal so schlecht an
